Can I configure a scan class in leased mode to have a low speed which results in never scanning?
If so, is there any way to check that it is working correctly? I can’t open a client to check, so how would I know?
Yes - a rate of zero means “off”
Yes, you could look in FactorySQL at the SQLTags system status (Under Connection > System Status > SQLTags), it will show you each scan class and when each one last executed.
