I am trying to scan the file system for UDT changes. The api route to scan projects and config does not work. How do I scan for gateway changes?
Tag changes would fall into the "config" scan endpoint, but you haven't provided much information:
- What value(s) are you changing, exactly?
- Which file(s) are you changing them in?
- What is your evidence that it "does not work"?
My mistake. I didn’t have security levels for the api set correctly.
