Is it possible to view scanclass in new versions of Ignition in SQLTagBrowser as it was in old versions?
I think that this is the very IMPORTANT parameter, and in newest versions it’s so much harder to see if the tags have it’s related scanclass… I have to open each tag and check which scanclass does it have…
And, no, you can’t preview the tag group from the main tag editor window. For one thing, it’s not universally relevant in 8.0+; tags can be truly event driven (reference, expression tags) and thus have no tag group whatsoever.
That said, better tools to organize, categorize, and report on your tags are on our list.
This ought to be fixed, btw. There were a number of columns available in v7.9 that weren't universal either, and they worked just fine. Simply empty where not applicable. Using universality as an excuse in v8 is just lame.
you know.. adding tags is not the thing which You do only once at the beginning of creating a new project.
During commissions and new additions to project we get new tags... and sometimes I (not only me) forgot to set tag group to new tags... and station starts to work very slowly or eats client's traffic... so... sometimes it's not so clear what happened and why this station works strange... but now I know that maybe I forgot to set the tag group...
I understand that You want to make our lives much easier, but sometimes old stuff works fine
I agree! from the other side it was the possibility to uncheck "scan class" to not see these empty fields...))
