I’m trying to import some tags into the tag browser via the OPC Browser using the Schneider OPC-UA server (not OFS). In the OPC Browser, I can navigate to the tag and expand it. The structure of the tag matches what I have in Unity Pro, but when I drag it into the Tat Browser, it changes. What steps am I missing here?
Thank you,
Ali
You only dragged a single tag in. What you see in the Ignition tag browser are Ignition’s tag properties.
Drag and drop for a folder will bring in all of its children, but not drag and drop of a tag with other tags underneath, since Ignition’s tag system doesn’t allow tags to be nested underneath other tags (only under folders).
You’ll have to drag the other tags in as well.
