Screen Resolution Help 1440x900
I have a screen that I designed to fit 1920x1080, only to realize that it will need to fit 1440x900. I changed the main window and got it to scale to the 1440x900. I have some floating windows that open on top of the main screen. No matter what size I change the floating screen, it does not display correct. The smaller I make the floating window the more Ignition blows it up. It doesn’t seem to change the size of the actual window. v7.9.12
Don’t let it open maximized. Then make everything in that window use Anchored layout.
I forgot about anchored and relative layouts. That helped tremendously.
