Screen Resolution / Tiny Ignition Question
Hi, I got a new Windows laptop and have a second, extended desktop hooked up. Resolution is at 1080. Ignition is so tiny… I can’t read anything. Have you guys come across this?
Chrs
your resolution is at 1080p on both screens? is the project tiny, or the designer, or both? is it tiny on both monitors?
yay, thank you! thank you!
You should also be able to use Java 9 with the latest release of Ignition to solve High DPI issues.
Assuming every install you support is running ignition 7.9.6 or higher
Yeah, Java 9 won’t play well with previous versions. You’d need Java 8 installed too.
