I have the following code to calculate formulas for a report.
total_good_parts_per_hour = 7713 * 3
# Calculate Choko and Bekido for each hour
chokoValues = []
bekidoValues = []
for i in range(1, 10):
goodPartsValue = data['goodParts24HR%d' % (14 + i)]
combinedValue = data['combined24HR%d' % (14 + i)]
if (goodPartsValue + combinedValue) != 0:
chokoValue = (goodPartsValue / (goodPartsValue + combinedValue)) * 100
else:
chokoValue = 0
if total_good_parts_per_hour != 0:
bekidoValue = (goodPartsValue / total_good_parts_per_hour) * 100
else:
bekidoValue = 0
# Store Choko and Bekido values in the data dictionary
data['Choko%d' % (14 + i)] = chokoValue
data['Bekido%d' % (14 + i)] = bekidoValue
Since it's in a report I don't know how to go about the debugging process due to the need for the tag historian Query I am using. What I am doing is looking at the XML of the report and seeing what values are being assigned.
<Bekido15>0</Bekido15>
<Bekido16>0</Bekido16>
<Bekido17>0</Bekido17>
<Bekido18>0</Bekido18>
<Bekido19>0</Bekido19>
<Bekido20>0</Bekido20>
<Bekido21>0</Bekido21>
<Bekido22>0</Bekido22>
<Bekido23>0</Bekido23>
<Choko15>0</Choko15>
<Choko16>0</Choko16>
<Choko17>0</Choko17>
<Choko18>0</Choko18>
<Choko19>0</Choko19>
<Choko20>97.6936856247201
<Choko21>0</Choko21>
<Choko22>0</Choko22>
<Choko23>0</Choko23>
These are the values I am getting. None of my combined vales or goodpcs values are 0.
<combined24HR15>179</combined24HR15>
<combined24HR16>172</combined24HR16>
<combined24HR17>58</combined24HR17>
<combined24HR18>51</combined24HR18>
<combined24HR19>269</combined24HR19>
<combined24HR20>412.0</combined24HR20>
<combined24HR21>104</combined24HR21>
<combined24HR22>378</combined24HR22>
<combined24HR23>48</combined24HR23>
<goodParts24HR15>12285</goodParts24HR15>
<goodParts24HR16>17008</goodParts24HR16>
<goodParts24HR17>7309</goodParts24HR17>
<goodParts24HR18>13133</goodParts24HR18>
<goodParts24HR19>11176</goodParts24HR19>
<goodParts24HR20>17452</goodParts24HR20>
<goodParts24HR21>13005</goodParts24HR21>
<goodParts24HR22>13561</goodParts24HR22>
<goodParts24HR23>16062</goodParts24HR23>
Is there some simple fix I am missing? Or is there some data error I have not found yet?
The modulo indexing syntax looks very strange.
How is it supposed to work?
Can you post the data so we can try your script.
The reason for the indexing is because I'm starting from 15. So I take 14 + i to go from 15 to 23.
The data is in the xml. I am pulling it from a tag historian query data source. There is no hard code for the values since they change daily.
Oh, yes. I only came across this once. It's modulo string formatting with a decimal conversion specifier so ['goodParts24HR%d' % (14 + i)] results in,
['goodParts24HR15']
['goodParts24HR16']
['goodParts24HR25']
Carry on then ...
Is that doing integer division, by any chance? Notice that 24HR20 = 412.0 (a float) and this gives a non-zero result.
Try
chokoValue = (goodPartsValue * 1.0 / (goodPartsValue + combinedValue)) * 100
to force float.
chokoValue = ((goodPartsValue* 1.00) / (goodPartsValue + combinedValue)) * 100
results in
<Bekido15>69.41527291585635</Bekido15>
<Bekido16>69.41527291585635</Bekido16>
<Bekido17>69.41527291585635</Bekido17>
<Bekido18>69.41527291585635</Bekido18>
<Bekido19>69.41527291585635</Bekido19>
<Bekido20>69.41527291585635</Bekido20>
<Bekido21>69.41527291585635</Bekido21>
<Bekido22>69.41527291585635</Bekido22>
<Bekido23>69.41527291585635</Bekido23>
<Choko15>99.70204841713222</Choko15>
<Choko16>99.70204841713222</Choko16>
<Choko17>99.70204841713222</Choko17>
<Choko18>99.70204841713222</Choko18>
<Choko19>99.70204841713222</Choko19>
<Choko20>99.70204841713222</Choko20>
<Choko21>99.70204841713222</Choko21>
<Choko22>99.70204841713222</Choko22>
<Choko23>99.70204841713222</Choko23>
But apparently
goodPartsValue = float(data[goodPartsKey])
combinedValue = float(data[combinedKey])
works fine
<Bekido15>53.092182030338385</Bekido15>
<Bekido16>73.50360862612905</Bekido16>
<Bekido17>31.587363325986427</Bekido17>
<Bekido18>56.756990362591296</Bekido18>
<Bekido19>48.299407926012364</Bekido19>
<Bekido20>75.42244695103506</Bekido20>
<Bekido21>56.203811746402174</Bekido21>
<Bekido22>58.60668136047366</Bekido22>
<Choko15>98.56386392811297</Choko15>
<Choko16>98.9988358556461</Choko16>
<Choko17>99.21270530745215</Choko17>
<Choko18>99.61316747572816</Choko18>
<Choko19>97.64962865880297</Choko19>
<Choko20>97.6936856247201</Choko20>
<Choko21>99.20665191852926</Choko21>
<Choko22>97.2881842312935</Choko22>
Good catch. They are all integer value type tags. I'm not sure why one got put in as a float while others did not.
