Script Editor can not Smart reminder
My Ignition Script Editor can not Smart reminder(Ctrl+Space).Has anyone encountered it? How to solve it?
Welcome!
In the script console, presseing Ctrl + Space immediately displays and, as, etc, but in the script editor section I need to type a minimum of “system.” then Ctrl + Space and it works.
Ignition version?
My Ignition version is 8.1.12.but in the script editor section I make “system.” ,it does not work
OK, I don’t have that version installed, maybe someone else that does can chime in
OK,Thanks for your answer
Which Ignition version you are using
seems to be working for me on 8.1.12
Are you using 8.1.12?
yes
Script Editor can Smart reminder?
in the editor i was able to press ctrl+ space after system. to get the list of functions
I also upgraded to 8.1.12,but this editor also can not press ctrl+ space after system. to get the list of functions.Why?
no idea :confused:
Thanks for your answer.You haven’t set anything?
nope, can you try in the script console? that one is a bit “smarter” image
Script console is able to Smart reminder
no idea then
OK ,I will look into it again
I have found the reason, because my computer’s hotkey conflicts. :sweat_smile:
