Yes I saw. And through the following script I get to create an OPC boolean tag from scratch.
# The provider and folder the Tag will be placed at.
baseTagPath = "[default]MyPath"
# Properties that will be configured on that Tag.
name = "BitAlarm_00_"
opcItemPath = "nsu=KEPServerEX;s=DR_1.CH_1.Allarmi[x].Allarmi[00].BitAlarm[x].BitAlarm[00]"
opcServer = "KEPServerEX"
valueSource = "opc"
dataType = "Boolean"
alarms = [
"name": "Alarm_0_1.",
"priority": "High",
"setpointA": 1,
"label": "Example",
"displayPath": "12345",
"shelvingAllowed": False
# Configure the tag.
tag = [
"name": name,
"opcItemPath" : opcItemPath,
"opcServer": opcServer,
"valueSource": valueSource,
"dataType": dataType,
"alarms": alarms
# Set the collision policy to Abort. Thus, if a Tag already exists at the base path,
# we will not override the Tag. If you are overwriting an existing Tag, then set this to "o".
collisionPolicy = "o"
# Create the Tag.
system.tag.configure(baseTagPath, tag, collisionPolicy)
My situation however is the following: I import the tags directly by importing them from KepServerEx, then it creates the variable tree with folders and subfolders of the various alarm tags.
From this situation I would like to alarm the various tags to be able to configure them. The problem is that I cannot add the alarm via script.
