Script function to check if a user password has expired
Is there any way to check if a user password has expired?, if not it would be great to implement it in a future release.
What would you do with this information? Genuinely curious - something like implement your own reset screen? Or send a notification somewhere?
Hi Paul,
Yes that’s right, I want to redirect users to a customized window where they could change their passwords through the User Management Component once these passwords have expired.
Hi Paul,
What do you think about my request?, implementing it would be great, since managing password expiration when using customized windows for logging in is a real pain in the neck
Well, the trick is that our authentication is a bit in flux right now - we’re going to move everything (including Vision) over to the identity-provider mechanism used in Perspective in 8.0, and there are some technical hurdles to detecting things like this. We also generally try to avoid things that only work with one “type” of something - we can easily detect an expired password with an internal user source, but might not be able to for an active directory source (depending on how it’s configured).
I would say, post to ideas.inductiveautomation.com. The more community interest we see, the more we’ll prioritize work on particular features.
Thank you for your answer Paul.
How can we detect an expired password when using an internal user source?
We don’t have any exposed mechanism to do so. You might be able to via some SDK methods, but it would be fairly fragile. Another option would be to use a custom module so you’ve got “sanctioned” access to the gateway context.
Hey Paul,
I was looking through the SDK for 8.1, and I have not found any references to a method that lets me know that a particular user in an internal user source has an expired password.
Can you please point me to a method as I would like to look into creating a custom module to check this.
Thanks,
Brandon
The InternalUserRecord class has a com.inductiveautomation.ignition.gateway.authentication.records.InternalUserRecord#PasswordDate field. You would compare that against the max age set on the user source.
