I’m trying to create an expression to set a value for a property tag
the first line works but the second causes an error.
if({Madera/TF2_Controller/TANK801}>{Madera/TF2_Controller/TANK801Hsp},1,0)
if({Madera/TF2_Controller/TANK801}<{Madera/TF2_Controller/TANK801Lsp},2,0)
You have to nest them, you can’t have two separate if statements in an expression. So it would be like this:
1,
2,
0))
Picky thing this script. I typed it as it looked but I may have had a space wrong. I copied it and pasted it and it worked.
Thanks, Now to figure out how to do indirect tags for popup chart.
I have 4 tags SP, HL, LL, Temp
