I’m getting this error when I’m trying to run this script. I haven’t seen it before, any ideas?
[code]<?xml version="1.0" ?>
def onStart(chart, step):
This will run when the step starts, before any
other action.
Arguments:
chart: A reference to the chart's scope.
step: A reference to this step's scope.
value0=0
chart.historyID = system.tag.read(chart.tagPath+"/HistoryID").value
system.db.runPrepUpdate("\
UPDATE\
PouHeader\
SET\
StatusID = 3,\
KitLocationID = NULL\
WHERE PHID = ?",
[chart.phID], chart.databaseName)
UPDATE\
CallButtonHistory\
SET\
Tstamp_off = ?,\
TerminationType = 1\
WHERE\
CallButtonHistoryID = ?,"
[system.date.now(), chart.historyID], chart.databaseName)
system.tag.write(chart.tagPath+"/Node/09_DORedLight",value0)</start-script>
</step>
[/code]
[code] 2:50:25 PM ChartInstance Chart ‘Charlotte/EPS_R1_0_0/ScannerHUD’ aborted in ‘Script[Step:dbUpdate10]’
File “”, line 20, in onStart
TypeError: str indices must be integers
at org.python.core.Py.TypeError(Py.java:235)
at org.python.core.SequenceIndexDelegate.checkIdxAndFindItem(SequenceIndexDelegate.java:74)
at org.python.core.SequenceIndexDelegate.checkIdxAndGetItem(SequenceIndexDelegate.java:61)
at org.python.core.PySequence.seq___getitem__(PySequence.java:305)
at org.python.core.PySequence.getitem(PySequence.java:301)
at org.python.pycode.pyx44410.onStart$1(:30)
at org.python.pycode.pyx44410.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call(PyFunction.java:376)
at org.python.core.PyFunction.call(PyFunction.java:371)
at org.python.core.PyFunction.call(PyFunction.java:361)
at org.python.core.PyFunction.call(PyFunction.java:356)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:636)
at com.inductiveautomation.sfc.elements.steps.StepScriptRunner.invoke(StepScriptRunner.java:46)
at com.inductiveautomation.sfc.elements.steps.StepScriptRunner.invoke(StepScriptRunner.java:34)
at com.inductiveautomation.sfc.elements.steps.action.ActionStep.activateStep(ActionStep.java:48)
at com.inductiveautomation.sfc.elements.StepContainer.onActivateRequested(StepContainer.java:125)
at com.inductiveautomation.sfc.fsm.element.ElementInactive.action(ElementInactive.java:33)
at com.inductiveautomation.sfc.fsm.element.ElementInactive.action(ElementInactive.java:8)
at com.inductiveautomation.sfc.fsm.StateContext.lambda$handleEvent$16(StateContext.java:52)
at com.inductiveautomation.sfc.fsm.StateContext$$Lambda$570/1970647362.run(Unknown Source)
at com.inductiveautomation.sfc.api.ExecutionQueue$ThrowableCatchingRunnable.run(ExecutionQueue.java:136)
at com.inductiveautomation.sfc.api.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:111)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)[/code]
