I am trying to write a script to update the content of a table so I do not need to use many cell binding calls and make it easier to update in the future.
I added the following script as a module
[code]def getFaultDataset():
stations = [2,9,10,11,12,13,14,17,20,21,23,25,26,27,36,38,42]
headers = ["Station", "Station Description", "Shift Faults", "Fault Percentage"]
data = []
for station in stations:
desc = system.tag.read("[]BodineB/Stations/" + station + "/Enabled.Tooltip")
data.append([row, desc, "", ""])
return system.dataset.toDataSet(headers, data)[/code]
Then in my table object I bound to this expression
runScript("app.getFaultDataset()", 10000)
However, I am getting the following error when it runs…
[code]Exception: Error executing expression binding on
Status.Root Container.Table.data
caused by ExpressionException: Error executing script for runScript() expression:app.getFaultDataset()
caused by Traceback (most recent call last):
File “expression:runScript”, line 1, in
TypeError: ‘com.inductiveautomation.ignition.common.script.ScriptModule’ object is not callable
Ignition v7.5.4 (b1206)
Java: Sun Microsystems Inc. 1.6.0_23
[/code]
Any help as to what I might be doing wrong?
