I am working in Ignition Vision 8.1 ....
I have a pop-up window with a number of custom properties. The custom properties are linked to fields by way of indirect parameters.
One of the indirect custom properties is an integer. This integer is run through a named query to retrieve a text value for a text label.
On initial opening of the screen, I receive a failure (every time)
java.lang.Exception: Named Query returned no rows on component: Motor Module Diagnostics.Root Container.Error Text.text
at com.inductiveautomation.factorypmi.application.binding.NamedQueryAdapter.handleQueryReturnedNoRows(NamedQueryAdapter.java:284)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$HandleNoRowsTask.run(QueryManager.java:518)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
Ignition v8.1.44 (b2024102210)
Java: Azul Systems, Inc. 17.0.12
The query is successfully run, and the data is displayed - but I am trying to understand why I get the failure. I think it is because of when the script is being run. I have numeric values for 0, as well as any other integer that may be in custom property. I suspect the scripts are running in a different order than I want - any suggestions?
