Script Tester and name 'isNull' is not defined
Hi!
I have a problem to use isNull() function within Script Tester.
I am getting error:
File “”, line 8, in
NameError: name ‘isNull’ is not defined
What I am thinking is that I have to import some module but I do not have idea which module.
Is there any manual regarding scripting and modules which has to be import to be able to use certain function?
Thank you
Hi, falko,
Null in python is None. There are two ways to check for something being None:
If value is None: doSomething else: doSomethingElse
If value == None: doSomething else: doSomethingElse
Or, to check if it’s not None:
If value is not None: doSomething else: doSomethingElse
If value != None: doSomething else: doSomethingElse
Thanks Jordan,
That is working.
But still iI have problem with some Expression Functions (Appendix B. Expression Functions from Ignition help). I try to use some of them in Interactive Script Tester, but I am getting similar error, for example:
NameError: name ‘toradians’ is not defined
or
NameError: name ‘toInteger’ is not defined
Question is where I can use them if they are not working in Script Tester?
Ah. Expression language and Scripting are two separate animals.
Expressions are used in Tags and Transaction groups. Scripts are python code.
Thanks Jordan,
That was something what I had to know.
Thanks a lot.
