Script to lookup a dataset tag and bring corresponding column values?
Hello I want to create a memory dataset tag which includes all desired info and want to have a script that looks for the value and brings corresponding desired column result for that value. I tried this;
OPName=lookup("[.]Dataset2",“1”,“Hata”,0,2)
system.tag.write("[.]CabinID",OPName).value
Dataset2 is a memory dataset tag
This is resulting an error like this;
Error executing script.
File “tagevent:valueChanged”, line 2, in valueChanged
NameError: global name ‘lookup’ is not defined
Could anyone help me with a code to achieve this.
BR,
Berkay
You’re mixing the expression language and jython.
To read the value of a tag you need to use system.tag.readBlocking().
That will return a list of qualified values, so you will also want to pull the value from that. Since your tag is a dataset tag, you will get the whole dataset returned. Code will look something like
ds = system.tag.readBlocking(["[.]Dataset2"])[0].value
OPname = ds.getValueAt(1,'Hata')
I am trying to use ignitions expression function lookup.It is I think the most convinient way of doing what I want. This is basically like an excel vlookup which is exactly what I want. I see this on the ignition manuel here;
https://docs.inductiveautomation.com/display/DOC79/lookup
Even though I try to use the same code in the link I keep getting lookup is not defined error do I need to import a library first? how to define it?
Please help here
You can’t use expression functions in jython scripts. Use an expression binding or an expression tag to use any expression function.
Thanks have not realized the expression bindings before really helpfull, got it to work what I need
