Script transform on Vision
On perspective, when we do a binding, we have option to do ScriptTranform, Why we can do it on VISION ?
Not directly. You have to move your binding to a custom property and perform your transform on a property change script.
Note: propertyChange events have to be checked in some way, so they only fire when the correct property change occurs.
Example:
if event.propertyName == 'myCustomProp':
     newValue = event.newValue
     # Do your transform on the new value here.
     # Then, assign the transformed value to the desired property.
     #component.regularProp = transformedProp
You can also use runScript() with a project library script (or component custom method) if you want it to evaluate on a binding even when the designer is not in preview mode.
I do it but when I change iduser, it not show anything on the label.
My syntaxe is incorrect ?
if event.propertyName == 'event.source.iduser':
	user_id = event.newValue
	event.source.getComponent('lbtest').text = "turbine engine " +str(user_id)
if event.propertyName == 'iduser':
	event.source.getComponent('lbtest').text = "turbine engine " + str(user_id)
merci @pascal.fragnoud
Est ce que je peux également lire une proprieté Custom "city" sur la vue en faisant binding par exemple:
        city = event.source.city # custom
	event.source.getComponent('lbtest').text = ciity + "turbine engine " + str(user_id)
est ce que ceci est correct ?
Other than the typo in ciity in the last line, that should allow you to add a custom property value to a label, so long as it is a string.
Note that you could also just do an expression binding on the lbtest.text property and achieve the same thing.
Oui, mais comme le dit @lrose, un simple binding fait l'affaire.
Ajoute cet expression binding sur ton label lbtest (note: I don't remember the actual path you need to use to access custom properties. Just use the property browser to select it):
{city_property}  + 'turbine engine ' + {userid_property}
There's no need to use property change scripts just for this.
If you script has other things to do, maybe they can also be replaced by simple bindings.
D'accord, merci.
I agree with @lrose and @pascal.fragnoud; a transform is overkill for this use case. The expression binding is the correct solution for string casting and concatenation.
