I am trying to add a dynamic property to an object. My code looks like this on a button referencing a paintable canvas:
[code]canvas = event.source.parent.getComponent(‘Paintable Canvas’)
props = canvas.getDynamicProps()
props.put(‘Test property’, ‘Test value’)
canvas.setDynamicProps(props)
print (canvas.getDynamicProps().get(‘imgHeight’).value)[/code]
When I go to preview mode and click the button, it seems to execute (I get output in the console), but my designer loses the ability to open script functions. When I try and re-open the script to change something, I get the following error:
[quote]Exception in thread “AWT-EventQueue-2” java.lang.ArrayStoreException: java.lang.String
at java.util.AbstractCollection.toArray(Unknown Source)
at com.inductiveautomation.factorypmi.application.binding.util.DynamicPropertyUtil.getProperties(DynamicPropertyUtil.java:51)
at com.inductiveautomation.vision.api.client.components.model.AbstractVisionComponent.getProperties(AbstractVisionComponent.java:145)
at com.inductiveautomation.factorypmi.application.binding.util.BindUtilities.getProperties(BindUtilities.java:489)
at com.inductiveautomation.factorypmi.application.binding.util.BindUtilities.getAllProperties(BindUtilities.java:504)
at com.inductiveautomation.factorypmi.designer.property.configurators.comptree.ComponentPropertyTreeModel.createPropertyChildren(ComponentPropertyTreeModel.java:94)
at com.inductiveautomation.factorypmi.designer.property.configurators.comptree.ComponentPropertyTreeModel.access$000(ComponentPropertyTreeModel.java:35)
at com.inductiveautomation.factorypmi.designer.property.configurators.comptree.ComponentPropertyTreeModel$ComponentNode.loadChildren(ComponentPropertyTreeModel.java:151)
at com.inductiveautomation.ignition.client.util.gui.tree.AbstractLazyLoadingTreeNode.checkChildren(AbstractLazyLoadingTreeNode.java:28)
at com.inductiveautomation.ignition.client.util.gui.tree.AbstractLazyLoadingTreeNode.getChildCount(AbstractLazyLoadingTreeNode.java:49)
at javax.swing.tree.DefaultTreeModel.getChildCount(Unknown Source)
at com.jidesoft.swing.TreeSearchable.populateTreePaths0(Unknown Source)
at com.jidesoft.swing.TreeSearchable.populateTreePaths(Unknown Source)
at com.jidesoft.swing.TreeSearchable.getTreePathes(Unknown Source)
at com.jidesoft.swing.TreeSearchable.getElementCount(Unknown Source)
at com.jidesoft.swing.Searchable.findFromCursor(Unknown Source)
at com.jidesoft.swing.SearchableBar.initComponents(Unknown Source)
at com.jidesoft.swing.SearchableBar.(Unknown Source)
at com.inductiveautomation.ignition.designer.gui.SearchUtility$CustomBar.(SearchUtility.java:87)
at com.inductiveautomation.ignition.designer.gui.SearchUtility.install(SearchUtility.java:56)
at com.inductiveautomation.ignition.designer.gui.SearchUtility.install(SearchUtility.java:52)
at com.inductiveautomation.ignition.designer.gui.SearchUtility.install(SearchUtility.java:46)
at com.inductiveautomation.factorypmi.designer.property.configurators.comptree.ComponentPropertyTreePanel.(ComponentPropertyTreePanel.java:72)
at com.inductiveautomation.factorypmi.designer.eventhandling.PropertyDialog.(PropertyDialog.java:48)
at com.inductiveautomation.factorypmi.designer.property.configurators.DBBrowserPanel$KeyPanel.(DBBrowserPanel.java:406)
at com.inductiveautomation.factorypmi.designer.property.configurators.DBBrowserPanel.initComponents(DBBrowserPanel.java:95)
at com.inductiveautomation.factorypmi.designer.property.configurators.DBBrowserPanel.(DBBrowserPanel.java:82)
at com.inductiveautomation.factorypmi.designer.eventhandling.DBBrowserBuilder.initComponents(DBBrowserBuilder.java:93)
at com.inductiveautomation.factorypmi.designer.eventhandling.DBBrowserBuilder.(DBBrowserBuilder.java:77)
at com.inductiveautomation.factorypmi.designer.eventhandling.ActionConfigPanel.(ActionConfigPanel.java:66)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.initComponents(ComponentScriptEditor.java:251)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.(ComponentScriptEditor.java:132)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.(ComponentScriptEditor.java:116)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler.configureEventHandlers(WindowWorkspace.java:2714)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler.configureEventHandlers(WindowWorkspace.java:2705)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler.handleConfigActions(WindowWorkspace.java:2700)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler.access$2000(WindowWorkspace.java:1984)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler$11.actionPerformed(WindowWorkspace.java:2156)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
[/quote]
I can’t open any scripting until I restart my designer. If I don’t try and put a new property in, commenting out the line that does so, like this:
#props.put(‘Test property’, ‘Test value’)
it will execute just fine and the designer keeps working as expected.
While I’m sure there is an error in my code, it seems like it shouldn’t break the designer…
