Script window key shortcut combos
I am not sure how to create a Title for this issue, so hoping you go through the description and get it
I need to use windows shortcuts, and link them to scripts.
I need to have a button which when pressed acts as a save only the image of the active window.
On Windows 10, this is achieved by keyboard shortcut “Windows + Alt + PrintScreen”
I need another button which takes screenshot of the entire screen and will save to the Pictures > Screenshots folder.
On Windows 10, this is achieved by keyboard shortcut “Windows + PrintScreen”
Can I add these key combos in a script?
The user screen is to be used in Kiosk mode, and the users do not have a keyboard to use and press these key combos
Details are important here. Are you using vision or perspective? If your using perspective, unless something changed I don’t believe it is possible. If your using vision and you want to save it somewhere then the windows short cuts I don’t believe would cut it since you want to have it saved somewhere in the background. A quick search though brings up what others have done to take and save screenshots.
How to take screenshots of your Ignition windows - Ignition - Inductive Automation Forum
In vision, use system.print.createImage()
This thread has some background on the difficulties of doing it in perspective:
I am using Vision 8.1.2
I am fine Windows saving in somewhere and I copy it to my location via another script
This link is quite helpful, I am going through it, and gonna try implementing.
