Script won't delete rows in database
Your named query is expecting a parameter id but you are supplying a parameter Customer_ID. Your dictionary of parameters should be {'id': id}.
Using this dataset, and the script below works correctly
table = event.source.parent.getComponent('Customer Power Table')
selRows = table.getSelectedRows()
if len(selRows) > 0:
	if system.gui.confirm("Are you sure you want to delete"):
  		for row in selRows:
  			id = table.data.getValueAt(row,"Customer_ID")
  			print "id: ", id
Also, @pturmel is right :smile:
Awesome, thanks!
I don’t know why the mismatch in parameters doesn’t generate an error, instead just silently exits with code 0.
Yes, I guess the output of 0, instead of the actual row id should have been my clue… Thanks for your help!
It’s not a “code 0”, but a count of the rows affected by the SQL statement.
