I am exporting a csv file, making changes to it, then importing it back in.
I am using the following code to bring the csv back in. Where do I find information on creating a file browser so I do not always have to have the file saved as a specific name, with a specific path?
Below is my current code:
#Specify file path
file_path = “C:\reciperesults.csv”
#Read in the file as a string
data_string = system.file.readFileAsString(file_path)
#Convert the string to a dataset and store in a variable
data = system.dataset.fromCSV(data_string)
#Assign the dataset to a table
event.source.parent.getComponent(‘New Recipe Creation Table’).data = data
Hi Joe, welcome to the forums!
system.file.saveFile() is the function you’re looking for.
#Specify file path
file_path = system.file.saveFile("reciperesults.csv")
if filepath != None:
event.source.parent.getComponent('New Recipe Creation Table').data = data
great! It works well, thank you. I am new to ignition and to python.
I had one issue where you used filepath, instead of file_path. Good exercise for me to interpret the error message though!!
