I have a table (lets call it “table 1”)on a screen displaying OEE and Throughput information. On the same screen i have a pie chart showing my downtime to operating time ratio (Lets call it “Chart 2”)
Question:
Is it possible to set the data binded to “Chart1” to the row selected by the user in “table 1”
Right now I have “Chart 1” binded to a SQL statement
SELECT Operating_Time, Downtime_Total FROM p4oee order by p4oee_ndx desc limit 1
And would like to give the users to view “Chart 1” data based on row selection from “table 1”
“Table 1” SQL Binding:
SELECT
Actual_Footage,
OEE * 100,
Planned_Time / 60,
Operating_Time / 60,
Downtime_Total / 60,
t_stamp
FROM p4oee
ORDER BY t_stamp DESC
I’ve tried finding the answer, but how do I capture multiple selected values/strings in a table?
The standard expression works great for a single selection, but I wish to return the results from a multiple interval selection into a SQL query.
The expression is:
if({Root Container.tblFeatureID.selectedRow} = -1,
“n/a”, // this is the fail case
{Root Container.tblFeatureID.data}[{Root Container.tblFeatureID.selectedRow}, “FeatureID”])
and the SQL query is:
select Operid, Sampleid, Featureid, Nominal, Actual, Deviation, Lowertol, Uppertol, Pass_Fail, Notes
from tblReporter
where FeatureID = ‘{Root Container.tblFeatureID.SelectedValue}’
order by SampleID
Rather than using an expression, with scripting you could use the getSelectedRows() method on the table to iterate through each row and build a string to use in your SQL query:
for row in event.source.parent.getComponent(‘Table 1’).getSelectedRows(): #use event.source.parent.getComponent(‘Table 1’).data.getValueAt(row,“yourColumn”)
You could put a dynamic string property on the table and when the selected row(s) change, fire off a script to rebuild the string, and use that string in your SQL query.
