The following error is occured by the script below it. Any Ideas?
Error:
Traceback (innermost last):
File “”, line 28, in ?
TypeError: Unable to convert row 5, column 1 to type class java.lang.String
at org.python.core.Py.TypeError(Py.java)
at com.inductiveautomation.factorypmi.application.script.builtin.DBUtilities.toDataSet(DBUtilities.java:233)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
at org.python.core.PyObject.__call__(PyObject.java)
at org.python.core.PyObject.invoke(PyObject.java)
at org.python.pycode._pyx3.f$0(<event>:28)
at org.python.pycode._pyx3.call_function(<event>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.factorypmi.application.script.ScriptManager.runCode(ScriptManager.java:227)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:142)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:281)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:54)
at $Proxy1.mouseClicked(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
Script:
[code]headers = [“ndx”,“phid”]
data = []
data.append([“DIOCFault”,event.source.parent.DIOCFaultDNC])
data.append([“DISWState1”,event.source.parent.DISWStateDNC])
data.append([“DISWTrip”,event.source.parent.DITripStateDNC])
data.append([“DILocRem1”,event.source.parent.DILocRemDNC])
data.append([“DIAutoOp1”,event.source.parent.DIAutoOpDNC])
data.append([“AIPhaseA”,event.source.parent.AIPhaseAphid])
data.append([“AIPhaseB”,event.source.parent.AIPhaseBphid])
data.append([“AIPhaseC”,event.source.parent.AIPhaseCphid])
data.append([“AIBat”,event.source.parent.AIBatphidDNC])
data.append([“DOSWState”,event.source.parent.DOSWphid])
data.append([“DOLocRem”,event.source.parent.DOLocRemphid])
data.append([“DOAutoOp”,event.source.parent.DOAutoOpphid])
#data.append([])
#ds = event.source.parent.SWControlDataSet
#ds[0,0] = fpmi.db.
#ds[1,0] = event.source.parent.DOphid
if ‘FPMIAdministrator’ in fpmi.security.getRoles():
if fpmi.gui.confirm(‘Are you sure you want to send a control to ’ +event.source.parent.SWName +’?’, ‘Confirm’):
fpmi.gui.openWindow("SwitchControl",{"DataSet":fpmi.db.toDataSet(headers, data),"SwitchName":event.source.parent.SWName})
else:
fpmi.gui.errorBox(‘Insufficient security privileges.’)[/code]
