Hi everyone,
i am currently developing a module based on the scripting-function project from the sdk-examples. I include the sapjco-3.1.11.jar in the modl build and create the following method to load jco classes:
@ScriptFunction(docBundlePrefix = "AbstractScriptModule")
public Class<?> loadJcoClass(
@ScriptArg("classPath") String classPath) throws ClassNotFoundException {
return Class.forName("com.sap.conn.jco." + classPath);
I can create the classes like this:
AbapException = system.example.loadJcoClass("AbapException")
This works out well but when i try to use these classes i get this error:
java.lang.ExceptionInInitializerError: java.lang.ExceptionInInitializerError: JCo initialization failed with java.lang.ExceptionInInitializerError: Illegal JCo archive "__3959807480__sapjco-3.1.11.jar". It is not allowed to rename or repackage the original archive "sapjco3.jar".
This happens because SAP does not allow to change the original jar filename but when i install the module to my Gateway the jars from the modl are stored in the jar-cache folder and receive a prefix to their name which leads to the error.
Any ideas to fix this?
