I am having issues with an http get request that I can get working using the http bindings but not when using scripting.
Below is a snapshot of the postman URL and headers:
Here's the code that I have. The getToken() functions works properly but the getSPP function gets the error that is also below:
Any help would be appreciated.
Thanks!
You need to be using named parameters here (even if that's not the issue, but try it).
client.get(url=fullUrl, headers={"Ocp-Apim-Subscription-Key": subscriptionKey, "Authorization":bearer})
That was it! Thank you, I appreciate the really quick response!
You should probably invalidate this bearer token now that you've posted it publicly.
I'd strongly recommend refactoring your script, for two main reasons:
- You shouldn't be instantiating
httpClient instances each time you call a project script. They're non-trivial to create, so this is slowing things down and potentially causing resource leaks. Move the call to system.net.httpClient out of the function definitions entirely so you can re-use it.
- Take advantage of the fact that httpClient can encode URL parameters and headers for you, instead of manually assembling full URL strings. This makes maintenance much easier:
client = system.net.httpClient()
def getToken():
url = "https://"
params = {
"grant_type": "password",
"username": "alfonso.lopez@example.com",
"password": "",
"response_type": "id_token",
"scope": "openid+",
"client_id": ""
response = client.post(url, params)
return response.json["access_token"]
def getSPP(token):
url = "https://example.com"
params = {
"deliveryDateFrom": "2024-08-25",
"deliveryDateTo": "2024-08-26",
"settlementPoint": "AMO_AMOCO_G1"
headers = {
"Ocp-Apim-Subscription-Key": "",
"Authorization": ("Bearer " + token)
response = client.get(url, params=params, headers=headers)
return response.text
Thank you for the upgrades and response. I'm sorry but as Kevin mentioned, I did not realize I had my information there such as email and the password. Any chance you could edit that and use fake ones?
Thank you!
