I’m running 8.0.13 and I’m unable to create new package and also unable to rename a package.
What are the names of your packages? Do you, by chance, have one named site?
You’re probably getting an error in the console.
You will likely need to rename these files on disk; if you go to the Ignition installation directory, then navigate to /data/projects/${yourProjectName}/ignition/script-python/${yourResourceName}, you can rename the entire folder and rest of the system should update itself automatically. You should ditch the _Class, at a minimum. Our known list of bad names didn’t specifically include it, but there are several similar entries:
"_bytecodetools", "java.nio", "_sre", "java", "_codecs", "copy_reg", "sysconfig", "traceback", "errno", "os.path", "_abcoll", "ntpath", "codecs", "org.python.google.common.collect", "encodings.utf_8", "linecache", "UserDict", "java.lang", "system", "re", "functools", "_jythonlib", "java.util", "nt", "sys", "encodings._java", "java.nio.charset", "StringIO", "_weakrefset", "org.python.google.common", "encodings.aliases", "array", "fpmi", "sre_parse", "org.python.google", "org.python", "types", "stat", "abc", "os", "org", "encodings", "warnings", "__builtin__", "genericpath", "org.python.core", "org.python.google.common.cache", "sre_constants", "site", "_functools", "java.util.Collections", "jythonlib", "sre_compile"
EDIT: Although, I can’t reproduce the issue you’re seeing even if I have four project scripts with the same names you do, so maybe it’s not a naming issue.
