Scripting reference parent property with parameter
Attempting to use Project Library script to change a parent component property.
The property name is supplied to Parameter prop.
The below script does not work I get an error stating the 'Object has not attribute 'Prop''
I have added a switch function using IF and ELIF which works except [props = value] does not set the property.
def propChange (comp, prop, dataset, event):
	par = event.source.parent
	compo = par.getComponent(comp)
	props = par.prop
	if props == 0:
		value = 1
	elif props == 1:
		value = 0
	props = value
	comp.setDatasetEnabled(dataset, value)
If you want to read a property (of a certain name) dynamically, use the Python builtin getattr:
	props = getattr(par, prop)
	if props == 0:
		value = 1
	elif props == 1:
		value = 0
	props = value
Assuming prop is passed in as something like "value".
You could get rid of the if/elif statements.
# if you really need an integer value
value = int(not props)
# if a boolean will work
value = not props
That code corrected the first issue. Now I having the the second issue which is that
props = value
does not set the property. The property is Boolean the parameter prop is passed in as a string.
Found the solution. I need to also uses setattr
	value = not props
	setattr(par, prop, value)
	compo.setDatasetEnabled(dataset, value)
