I’m on 8.1.1
I have un bunch of specific tags that I want to list path in a memory StringArray.
I use a system.util.getGlobals() variable to store path then wrote the system.util.getGlobals() into a memory tag.
My problem is that each tag event (i’m on valueChange and quality change) is fired before the previous tags finish is procedure.
Is there a way to be sure that each tag event is comleted is procedure before lauching an other ?
