Scripting the Save As Excel method of the Report Viewer Component
I see there is a right click menu option to “Save as XLS”, but I can’t find a way to access this functionality via a script the way the “Save as PDF” can be done using the “saveAsPDF” method. Is this not a built in function of the Report Viewer? Is there a way to glean what the right click menu option does in order to reproduce it?
Thanks,
Mike
Execute and distribute is what you want.
https://docs.inductiveautomation.com/display/DOC79/system.report.executeAndDistribute
Or even, creatively, componentReference.saveAsXls(filename) - since that’s all that the popup menu is doing anyways.
Thanks for the helpful input! :smiley:
