I have a UDT called “Motor_Block” that I am trying to utilize on a template. I was originally using an indirect tag, but have changed to using a property of the UDT in a script.
The script is as follows:
x = system.tag.read (“event.source.parent.parent.MotorTag.PROG_AUTO”)
if x.value is True:
system.tag.write(“event.source.parent.parent.MotorTag.PROG_AUTO”, 0)
else:
system.tag.write(“event.source.parent.parent.MotorTag.PROG_AUTO”, 1)
When I run in Preview mode and click on the group associated with the script, I get the following error:
File “event:mouseClicked”, line 2, in
ValueError: Token PROPERTY_SEPARATOR found after property name.
Ignition v7.6.1 (b2278)
Java: Sun Microsystems Inc. 1.6.0_45
Any assistance would be greatly appreciated!
