Scripting Value Changed runs every time I write to a DataSet
Hi, I'm trying to make a call using Tag Change but every time it writes data to DataSet it runs scripting Value changed, even if the values or quality doesn't change how to avoid this?
I use such a simple function to save DataSet
datasetNew = system.dataset.setValue(dataset, 1, "Operation", True)
system.tag.write('[default]TST/FarmOperation', datasetNew)
Best regards,
Michał
Datasets are always new objects, no matter their content. Your script should check the content and skip the write based on your own idea of "changed" or "not changed".
I understand that I will not use this functionality for this case - DataSet
Sames is true for documents and arrays. They are all-or-nothing objects, and any assignment to such tags are always a new value.
I was hoping that this is somehow internally resolved. I will prepare my script thank you for your quick response and explanation.
