My main aim is to use python system functions and make a module according to our application.
I am trying to extract tag historian Data through SDK module programming.
I have taken managed-tag-provider example provided by the SDK as my skeleton project and trying to run ignition's system functions through scriptManager.runFunction().
I am stuck with trying to implement the mentioned function.
Here is the code which i have tried:
public List<Map<String, Object>> getTagHistory(String tagPath, Date startDate, Date endDate, int returnSize) {
String functionName = "system.tag.queryTagHistory";
Map<String, Object> args = new HashMap<>();
args.put("paths", new String { tagPath });
args.put("startDate", startDate);
args.put("endDate", endDate);
args.put("returnSize", Integer.valueOf(returnSize));
result = script.runFunction(functionName , args);
return (List<Map<String, Object>>) result;
script is a global instance of ScriptManager.
I am getting this error : Cannot resolve method 'runFunction(String, Map<String, Object>)'
I understood the method signature is different. But I am not able to implement this function.
Any example on how to use this method would be really helpful.
Thanks for your reply. I had changed my plan from using Jython to Java and though I am not getting any errors but tag history is returning only 1 row. As I was checking for rowCount() in the logger, Though it logged so many values in the span of 5 minutes on change, but the function only logged 1 as the getRowCount() result in the gateway logs.
Function:
public void getTagHistory(String tagPath, Date startDate, Date endDate) throws IOException {
This function is called in startup lifecycle event with required params.
If I add returnSize param of BasicTagHistoryQueryParams to 1000:
Though I am getting rowCount as 1000 . they are all the same values without change.
When we configure tagHistorian, we configure the data to be logged into database only when the tag value is changed. However, i am finding all the values upto some rows are the same.
