Scripts are not updated
I'm experiencing the following issue (Ignition 8.1.34): scripts are not always updated when I save the project. To be more precise: they get updated for some time after Ignition service restart and then they stop being updated and the Ignition service must be started again.
Any idea?
Not sure if that has anything to do with my issue: when I save the project, the following exception gets logged to the wrapper:
Yup, looks like a problem. You will likely need help from support--those are IA code paths.
I'd recommend starting with the simplest possible solution: upgrade your gateway.
