Scripts flagged as changed just by opening them v8.1.19
v8.1.19, by simply opening a script, it is flagged as changed, which then in turn sends an audit event for resource modified. Did not notice this until updating to v8.1.19. Also, opening a script is laggy, I assume due to the extra “stuff” that was added into scripting.
Will send this to support as well.
From IA support, this is a bug, albeit a very tiny one. It is centered around autocomplete functionality as well as the ability to specify Scope for hints you get when using system functions.
This only happens the first time a script is opened, and most likely only when updating from a previous version.
