Scripts won't run
Hello,
I'm a beginner in Ignition and have a progblem with the scripting.
I've written both a timer and a scheduled gateway event script but they don't appear to run. The scripts are enabled and I've saved the project but if I go to the Ignition gateway diagnostics there aren't any script shown, only "No script entries found".
Do you have any advice where the problem might be. I've went through the documentation on scripting but can't seem to find any major thing i did wrong.
I would start with making sure the project is enabled.
Hi Sven,
Addtionally, if you could attach your gateway scripts, screenshots, and any other information that would help us in assisting you.
The Ingition gateway is at the moment being used as a PLC to OPC-UA "translation" layer which has been active for weeks already. So I assumed the project was already enabled, I assumed wrong...
Thanks for the reminder.
