Seach Bar Component
It possible to do search component? with filter ? such search by first name or search by lastname.?
It depends, what data are you searching? Data in table? Data spread across multiple items across a page? You mention first name/last name, are you searching through a list of users and then only want to show the users that match the search term?
Provide an example interaction flow, something along the lines of:
'When the operator commands a search, all process values with display names containing the search key are highlighted on the currently open window'
The more specific you can get the better, as it will help others to better direct their solutions to match your case.
Data from Data Base Tables
Is it Vision or Perspective?
Try to atleast answer in more than a few words when someone says you have to be specific...
