Using V 7.3.2
Is there an easy way to search and replace through all scripts and bindings in a project?
Using V 7.3.2
Yes, just press Ctrl-F in the Ignition designer. You have the ability to search all scripts and bindings.
So i am trying to change the path of all of mt tags from
OEEDemo\Your Enterprise\Your Site
TO
BLAH\BLAH\BLAH
When i perform the search and replace i get a new path of
BLAHBLAHBLAH
with the \ Removed.
Sounds like the replace function isn’t escaping the “” for you. We should fix this, but in the mean time, try replacing with:
“BLAH\BLAH\BLAH”
Regards,
Worked Like a charm
