Im basing my answer in perspective but the same applies to vision, I’m also assuming your search box is a text field box.
This is how I do it to enable wild cards on the search.
On the text field box create 2 custom properties. One called ‘whereclaus’ and one called ‘keyword’
The whereclaus expression is (Description is my database field)
if ({this.custom.Keyword}='',
"Description >= ''",
concat("Description LIKE '",{this.custom.Keyword},"'")
The keyword expression is
{this.props.text}
but it has a transform expression of
'%'+{value}+'%'
Now, in your sql query / Named query (in my case) I add ‘Description’ as a Query String
and use the following as an example…
SELECT DATE_FORMAT(Date, "%m-%d-%Y") AS 'Date',
RequestNumber As 'Request Number',
PONumber AS 'P/O',
ProjectNumber As 'Project No',
Supplier,
Requester,
DeliverTo As 'Deliver To',
PartNumber As 'Part No',
Description,
Qty,
PriceEach As 'Cost Each',
TotalCost As 'Line Cost'
From order_requests
WHERE Status = 'Ordered'
AND {Project}
AND {Supplier}
AND {PartNumber}
AND {ReqNumber}
AND {Description}
AND {Classification}
Order by id Desc
With the %% as part of the expression, as soon as you type a letter it will start matching everything with that character.
I forgot to add, Dont forget to go back to your table query and add the whereclaus you just created on the text field in the table parameters.
