SearchReplace - Error during search. com.inductiveautomation.ignition.common.gson.JsonSyntaxException
How would I locate the dodgy View that's causing the find/replace tool to fail? I have 417 Views, so saving them 1-by-1 is a bit unrealistic
20:26:40.619 [ForkJoinPool.commonPool-worker-5] WARN SearchReplace - Error during search.
com.inductiveautomation.ignition.common.gson.JsonSyntaxException: com.inductiveautomation.ignition.common.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 6149 path $
at com.inductiveautomation.ignition.common.gson.Gson.assertFullConsumption(Gson.java:903)
at com.inductiveautomation.ignition.common.gson.Gson.fromJson(Gson.java:866)
at com.inductiveautomation.perspective.common.config.ViewConfig.fromProjectResource(ViewConfig.java:104)
at com.inductiveautomation.perspective.designer.search.ViewSearchContext.getView(ViewSearchContext.java:66)
at com.inductiveautomation.perspective.designer.search.ViewSearchCursor.initialize(ViewSearchCursor.java:29)
at com.inductiveautomation.ignition.designer.findreplace.AbstractDeferredCursor.next(AbstractDeferredCursor.java:21)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.advance(SearchObjectAggregator.java:119)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.next(SearchObjectAggregator.java:107)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.next(SearchObjectAggregator.java:89)
at com.inductiveautomation.ignition.designer.findreplace.SearchObjectAggregator.next(SearchObjectAggregator.java:31)
at java.base/java.util.Iterator.forEachRemaining(Unknown Source)
at java.base/java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
at com.inductiveautomation.ignition.designer.findreplace.DefaultSearchExecutor.search(DefaultSearchExecutor.java:40)
at java.base/java.util.concurrent.CompletableFuture$AsyncRun.run(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$AsyncRun.exec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.scan(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 6149 path $
at com.inductiveautomation.ignition.common.gson.stream.JsonReader.syntaxError(JsonReader.java:1568)
at com.inductiveautomation.ignition.common.gson.stream.JsonReader.checkLenient(JsonReader.java:1409)
at com.inductiveautomation.ignition.common.gson.stream.JsonReader.doPeek(JsonReader.java:542)
at com.inductiveautomation.ignition.common.gson.stream.JsonReader.peek(JsonReader.java:425)
at com.inductiveautomation.ignition.common.gson.Gson.assertFullConsumption(Gson.java:899)
... 24 common frames omitted
20:26:42.590 [ForkJoinPool.commonPool-worker-5] WARN SearchReplace - Error during search.
Unfortunately, there's no way I can see to get a better idea (from find & replace) which view it's bombing out on.
You could try a script that looks at each view.json on the filesystem; it looks like the one that's an issue has no line breaks and is totally invalid (a bad script to write an updated view json, maybe?)
Based on: Caused by: com.inductiveautomation.ignition.common.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 6149 path $
