Security and Roles (Vision & Perspective)
Hi, so i Created some users and roles and wanted to use them for security in my Project. It happens that i cant see the specific roles, only "roles"
As you can see i have them created:
Shouldn't appear the roles i created in security level automatically?
Also, in Vision i cant select security or see the window about it. In any componente or even the root or window, if i try going to security it does not open anything.
Does anyone know if it is a module that is missing or a bug?
You'll need to add the roles into the identity provider's security levels in the web config page. These aren't automatically added
https://docs.inductiveautomation.com/display/DOC81/Security+Levels
Thank you!
And About Vision Security, do you happen to know about it?
Is it a tab in one of your palettes? Usually it's a tab in the component property palette
