Security Concerns Regarding User Access to Tags in Perspective
Hello,
I have a tag that stores a token required to upload data to a cloud storage system. This token refreshes every hour. I also have a Perspective button that executes a script using that token to generate a temporary URL, which is then used to display a file.
My concern is security — I don’t want the end user to have any access to the tag or token. At the same time, the user needs read privileges for the script to work.
Is there any way for the user to access the value of that tag if it’s not displayed anywhere? Should I consider a different approach?
Thanks!
It isn't a question of display. If you bind that tag to a Perspective property (anywhere), and that property isn't marked as private, then you are publishing that tag to the browser. Also for any script assignment to a Perspective property. A competent coder can examine browser state to find it.
If you are using system.tag.readBlocking() in your script, then you are safe, as scripts run entirely in the gateway.
I have the tag set to private and I’m accessing it through system.tag.readBlocking(). Why does the user still needs to be within the required security level for readBlocking to return a value? If readBlocking runs on the gateway, I don’t get why Ignition is checking the user security level.
As for the example:
  • My token tag (private): [default]Tokens/mytoken
  • Scripting library function:
# project.library.cloud
def getFileUrl(file_id):
    token = system.tag.readBlocking(["[default]Tokens/mytoken"])[0].value
    return build_url(file_id, token)
  • Perspective button:
url = cloud.getFileUrl(self.view.params.file_id)
#do something with the url
Thank you
What does this mean? (In my comment above, I was referring to setting a Perspective property to private, if you were using a tag binding.)
The whole point of tag security is to provide a barrier that UI programmers don't have to think about. Ignition will stop the use of tags from UI events that don't have the appropriate access.
Perhaps you should be caching your token in a library script module top-level dictionary or similar persistent variable.
Under tag security, I’ve configured read permissions to be allowed only for my “admin” security level (which the Perspective user does not belong to). From my understanding, readBlocking should not check whether the user is within that security level, since it executes on the gateway side.
Perspective scope is a subset of Gateway scope, and will enforce tag permissions. My presumption in my first comment was that you weren't using tag permissions.
(Hiding things from a designer is pointless--designer access restrictions are only guardrails once logged in.)
So, setting the tag’s read permissions to public is safe as long as the tag isn’t bound anywhere, right?
Neither bound nor assigned to a Perspective property. If you really want to avoid exposure, use a script top-level variable to hold your token.
I'll just echo this. If you're concerned about exposure, why use a tag at all?
I can use the same token every 60 minutes (across the entire gateway and for all clients) before generating another one. Creating a new token for each request would be inefficient. I can't think of a cleaner way to manage it than with a tag that refreshes every hour.
A script top-level variable to hold the token, and a Gateway Scheduled Event (Or a Timer Event if you don't care about the update being on the hour). The gateway event would call a project library script which updates the variable.
I’ll try that, thanks!
Spanning multiple projects of a gateway might benefit from a solution that does not utilize a project-based resource.
Inheritance plus careful use of a gateway-wide persistent dictionary is the answer to that, too.
My emphasis added.
