I am trying to setup a security zone using the gateway names identifier.
For testing I setup a label with an expression binding to the text property.
The expression I use is: isAuthorized(true,'SecurityZones/ACME')
The expression will evaluate either True or False. I can use the IP Address Identifiers field with success. I can use the Host Names Identifiers field with success. No matter what I enter in the Gateway Names Identifiers field the expression will evaluate false. Even when I just enter the wildcard ‘*’, which works in both the IP Address and Host Names, the expression evaluates to false. I have copied the gateway name off of the gateway home page. I have set up a tag binding to another label, binding the text property to [System]Gateway/SystemName and copied that to the gateway names identifiers field.
I’m out of ideas. Is this feature just broken, or am I missing something?
