I have two classes that I want to make available to project scripts running on the gateway.
If I register one class, the module installs and starts up with no errors or warnings in the wrapper.log.
If I register both classes, warnings appear in the log, as shown below.
This is the code in the module:
@Override
public void initializeScriptManager(ScriptManager oScriptManager)
oScriptManager.addScriptModule("xas", new MyClassA());
oScriptManager.addScriptModule("xas", new MyClassB());
I’ve specified “xas” for the location, assuming I can create namespaces at will, so long as they are unique.
MyClassB extends MyClassA.
This is a typical warning at gateway startup:
INFO | jvm 1 | 2016/09/22 15:10:18 | Warning: collision at xas.Description
Description is a protected String in MyClassA, so it also visible in subclass MyClassB.
It seems to me that there should not be any path “xas.Description”. The class name should be in the path: xas.MyClassA.Description
I’m getting warnings for five of the six protected variables, and for one of the six public methods, that are declared in MyClassA.
I’m not getting any warnings for variables or methods declared in the subclass MyClassB.
Suggestions?
Thanks.
