craigb
              1
              From the following query, what do I need to add to be able to select the last row only.
Can either be the index number or t_stamp.
SELECT ACC_2_Piston_Pressure, Back_Pressure_SP, Back_Pressure_Time, Charged_Volume, Chill_Timer, Extruder_Pressure, Extruder_Temperature, Joint_Cast_Date_Time, Joint_Volume_Used, Lock_Bar_Pressure, Mould_Fill_Time, Purged_Volume, Total_Joint_Time, t_stamp, Joint_Number, Total_Joint_Timer, Mould_Fill_Timer
FROM impp_logs
ORDER BY t_stamp DESC
This is so my report viewer only shows the latest row in the table.
                diat150
              2
              SELECT top 1 ACC_2_Piston_Pressure, Back_Pressure_SP, Back_Pressure_Time, Charged_Volume, Chill_Timer, Extruder_Pressure, Extruder_Temperature, Joint_Cast_Date_Time, Joint_Volume_Used, Lock_Bar_Pressure, Mould_Fill_Time, Purged_Volume, Total_Joint_Time, t_stamp, Joint_Number, Total_Joint_Timer, Mould_Fill_Timer
FROM impp_logs
                craigb
              3
              Error running query:
SQLQuery(query=SELECT top 1 ACC_2_Piston_Pressure, Back_Pressure_SP, Back_Pressure_Time, Charged_Volume, Chill_Timer, Extruder_Pressure, Extruder_Temperature, Joint_Cast_Date_Time, Joint_Volume_Used, Lock_Bar_Pressure, Mould_Fill_Time, Purged_Volume, Total_Joint_Time, t_stamp, Joint_Number, Total_Joint_Timer, Mould_Fill_Timer
FROM impp_logs
ORDER BY t_stamp DESC, database=mobile)@5000ms
On: Logging PDF.Root Container.Report Viewer.IMPP
                nmudge
              4
              You didn’t say what database you are using. It is different if you are using MySQL or SQL Server.
Try this for MySQL:
FROM impp_logs
LIMIT 1
                craigb
              5
              A apologies folks, I never knew the code would be different for different databases.
When I was goggling I was searching “SQL last DB entry”. No wonder I was scratching my head for so long as I am indeed using MySQL
                nmudge
              6
              No problem. Totally understandable.
