I need a script to run on a slider bar to change the Y axis upper or lower bound on the easy chart.
Actually, I need to be able to vary the Y axis of each line independantly on a classic chart. The idea is that I can move the lines on the chart to more clearly compare their shapes.
Tada! ask and you shall receive
There is just a bit of scripting involved to alter the y-axis bounds on the fly. Also, each pen needs to be on its own y-axis to be moved independently.
moveablelines_window.fwin (48.8 KB)
