I have a huge json dataset.
I can select more rows in the perspective table.
In the props.selection.data propertie I find my rows.
In the props.selection.selectedRow I find my first selected rowindex.
I want to delete all selected rows in a script.
the system.dataset.deleteRows() removes only the rows specified by index.
I dont want to loop through my full dataset because of performance issues occuring then.
How do I remove the selected jsonrows from props.selection.data from the props.data or how do I know all the rowindexes and not only the first one without the need to loop through the whole table?
Also ran into this issue when on mobile, trying to select multiple rows. I can add the event.value object to props.selection.data but can’t figure out how to make the table visually reflect multiple selected rows without a keyboard to hold the ‘ctrl’ button.
@joostjojo, I’m having the exact same problem now. Did you ever solve your issue?
I have populated a Perspective Table with data, then will send that data in a query to a database.
My issue is I need some way of deleting multiple rows of the table before I initiate the query.
I would’ve expected the props.selection.selectedRow to either change into a list [3,8,11] or something that would indicate when more than one row is selected.
To have to loop through all the selection.data to find the indices of those rows seems painful.
@cmallonee, do you or anyone else have a workaround? Maybe this should be a feature request?
Apparently, it already is.
As a workaround, I've tested this and it works (for anyone that's still interested):
# Get the table data
ds = self.parent.parent.getChild("Table").props.data
# Convert dataset to PyDataset for easier iteration
pyData = system.dataset.toPyDataSet(ds)
# Get the selectedData
selectedData = self.parent.parent.getChild("Table").props.selection.data
selRows = []
# Loop through props.selection.data and props.data to find indices of selectedRows
# selRows is the resultant list of rows (indexes) that have been selected
for i in selectedData:
pos = 0
for row in pyData:
if row['ColumnName'] == i['ColumnName']:
selRows.append(pos)
pos += 1
# Delete rows based on selRows
ds = system.dataset.deleteRows(ds, selRows)
# Write the dataset back to the table
self.parent.parent.getChild("Table").props.data = ds
# De-select all rows in the table
self.parent.parent.getChild("Table").props.selection.selectedRow = None
I still hope they make props.selection.selectedRow return a list of rows actually selected, not just the last one.
I'm still waiting for the fix to be implemented! thanks for the work around
I generally post-process the table source data with my toolkit selectStar() function to add a column containing the original data row index within the table data. As long as this is present in props.columns, usually hidden, this extra index will show up in rowData as well as filtered and sorted feedback properties.
selectStar(
{path.to.source.data},
asMap('sourceIndex', 'I'),
idx()
