Selecting component deep select go up in view hierarchy
Hi
When I want to select a component in a tab view the deep select go up in view hierarchy instead of selecting the component.
The problem started when a started pipes.
When I copy the view there is no problem until I start to work with pipes again.
If I close the designer and open again, there is no problem until I start to work with pipes again.
I'm using V8.1.47, and I didn't have this problem in V8.1.43
Does some one have a solution for this?
Support has confirmed that there is in bug in the system, and it will properly be solved in update.
