Hello again guys (skip first paragraph for short entry,)
As I get deeper into working with this program, I find more things that don’t seem to have the straightforward API support that other stuff does, so I am lead here to see if anyone else knows how to do what I’m trying to do, and I feel a little guilty each time. To the point though, what I’m trying to do, is use the MouseClicked script within the Table component to select multiple rows in the table. So I took a look at the setRowSelectionInterval method. It’s close to what I want, but the rows I want to select are not always right next to each other, and I can’t reorder the table to get them next to each other either (due to the nature of the table).
How do I select multiple rows in a table component that are:
1) Not next to each other
2) Without reordering the table
I do not believe that the setRowSelectionInterval method can help me.
Yeah, I guess it isn’t documented. I just picked up somewhere that getTable will return the actual JTable object. From there you have access to basically everything inside a standard java JTable. It would probably be helpful if the user manual highlighted how to get to underlying objects, along with a link to the java documentation.
[quote=“dep05d”]Yeah, I guess it isn’t documented. I just picked up somewhere that getTable will return the actual JTable object. From there you have access to basically everything inside a standard java JTable. It would probably be helpful if the user manual highlighted how to get to underlying objects, along with a link to the java documentation.
Dan[/quote]
Oh, ok Thanks Dan. I’ve ran into that problem before, where there is something in the API but isn’t documented. Do you know if there is another place where I can get more documentation for Designer, cause I don’t like going to the forum each time when something I need isn’t in the API.
Not really, sorry. If I’m stuck on something, I’ll generally search the manual, then search through the forum, then try and see what java I can get into under the hood, then ask here or call support if I’m still stuck.
I wouldn’t feel guilty about posting here. It helps build a knowledge base for the community and highlight documentation gaps / needed features. And inevitably, you’ll find plenty of opportunities to answer questions to problems you’ve already encountered.
Set the table property ‘Selection Mode’ to ‘Multiple Interval’. Mouse and will select/deselect interval rows (mouse and will select/deselect contiguous rows).
Use getSelectedRows() to return a list ints of selected rows.
[quote=“dep05d”]Not really, sorry. If I’m stuck on something, I’ll generally search the manual, then search through the forum, then try and see what java I can get into under the hood, then ask here or call support if I’m still stuck.
Good Luck!
Dan[/quote]
Ok thanks Dan, fortunately, I am actually a bit familiar with Java, as it was my first language, but I had no idea how much Ignition Designer depended on it, I’ll check java docs as a resource from now on. Thanks.
