Hello,
I have an integer tag and I would like to be able to set every bit individually with a button in that integer.
Now for scripting I have found to use
def set_bit(value, bit):
return value | (1<<bit)
def clear_bit(value, bit):
return value & ~(1<<bit)
def getBit(value, position):
return (value >> position) & 1
value = event.source.parent.DATA_Sequentie.Selectie
if getBit(event.source.parent.DATA_Sequentie.Selectie, 0) == 0:
value = set_bit(value,0)
event.source.parent.DATA_Sequentie.Selectie = value
else:
value = clear_bit(value,0)
This works perfectly except I have to write te number 0 to the specific bit every time I make another button. I have to do this at the 3 different places the “0” bit is stated which could lead to forgetting this in the future. I would like this to come from one general place. Like a custom property for example where you have to write the bit number. Problem is I can’t get this to work.
Do you guys have any other suggestions on how I could set bits from an integer or how to get a custom property to work?
Thanks in advance!
