Self reference in expression bindings
Is it possible to self-reference a component in the expression binding on the same component?
Currently, I’m using this:
if(isNull({Root Container.ContainerObesalo.lblStatusOkretanjeBubnjeva.vrednost}),
	{Root Container.ContainerObesalo.lblStatusOkretanjeBubnjeva.text},
	case({Root Container.ContainerObesalo.lblStatusOkretanjeBubnjeva.vrednost},
		0,"ISKLJUČENO",
		1,"NAPRED",
		2,"NAZAD",
		4,"GREŠKA",
		"ISKLJUČENO"
But it’s very time-consuming…
I was also trying like this:
if(isNull({self.vrednost}),
	{self.text},
	case({self.vrednost},
		0,"ISKLJUČENO",
		1,"NAPRED",
		2,"NAZAD",
		4,"GREŠKA",
		"ISKLJUČENO"
Obviously, that doesn’t work, but I almost can’t believe, that expression self-referencing isn’t possible…?
Is all of this data coming from a single UDT instance (hopefully)? If so it might be easier to do it in the UDT.
I do wish that you could self-reference.
No, there is no UDT…
This property ({Root Container.ContainerObesalo.lblStatusOkretanjeBubnjeva.vrednost}) is binded to a normal tag.
I’m not sure whether you can use the self keyword on a binding like this (I would think you can). But you definitely can’t reference a binding ({Root Container.ContainerObesalo.lblStatusOkretanjeBubnjeva.text}) in its own definition. A binding replaces the value and therefore can’t reference it.
Give this field a default value, and you shouldn’t get an error anymore:
	"<Default Value>",
		0,"ISKLJUČENO",
		1,"NAPRED",
		2,"NAZAD",
		4,"GREŠKA",
		"ISKLJUČENO"
If that works, then try using the self keyword to see if you can shorten your code.
I don’t get any errors.
My first/current code ({with full property path}) works just fine.
Expression code with {self.text} and {self.vrednost} also doesn’t throw any errors, it just won’t work.
What I mean/need is something like this in SQL query binding:
Hello zxcslo,
Have you found a solution for that?
With kind regards
It isn't available on expression bindings because it makes a circular reference, and weird behavior on expression startup.
Hello pturmel,
Thanks for the reply.
I wanted to link the name of a template instance to the mouseover text.
But by doing this once manually and copy/paste the template, it keeps working, so that works well enough for me.
